LG4- Chasing Misfire and Rev Hang
Old Mar 21, 2024 | 08:56 AM
midnightfirews6's Avatar
Car: 1984 Trans Am WS6
Engine: LG4
Axle/Gears: 3.23 LSD
Been having weird issues with my '84. LG4, still with the e4me and digital spark advance. Auto>t56 swapped. It's been having an intermittent part throttle (~1/4 throttle in any gear) misfire that feels like spark, but i've gone through the whole ignition twice, dizzy to spark plugs. I've also replaced the carb twice with remanned units from national carburetor due to leaks. The intake manifold has also been cleaned and resealed last year due to a coolant leak. I'm at my wits end trying to chase this down. Otherwise, it starts fast and consistently and runs great above ~1/4 throttle. I'm not sure that the secondaries are even kicking in when it clears up and runs well. It has an intermittent cel for running rich. The other weird thing is that the revs hang above 35 mph. any gear, clutch in or out, cruise on or off, a/c on or off. They just sit around 2k +/-500 rpm, and the pedal gets sucked down like the cruise is set until i slow below exactly 35 mph. I haven't changed the ecm. Considering trying that or going m4me/ vac advance, but i'd like to hear other opinions before throwing parts at it.
Old Mar 21, 2024 | 10:09 AM
Vader's Avatar
Re: LG4- Chasing Misfire and Rev Hang
Does the carb have a high idle solenoid? If so, is that adjusted properly? It can be unplugged or removed for diagnosis of the issue.
Another thought is that the something is allowing extra air, either from binding throttle plates, stick shafts, a leaking EGR possibly commanded ON by the ECM, an incorrect PCV valve, or some other source.
Old Mar 25, 2024 | 07:17 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
yes
The ECM will command the high idle solenoid above a certain speed in decel
what's the dwell doing at part-throttle? don't assume the mixture is rich at part throttle even with a 'rich' CEL code.
Old Mar 25, 2024 | 03:24 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
You say you haven't changed the ECM but did you swap the PROM to the LG4 manual version? The auto PROM uses the
Park/Neutral switch on the shifter to let the ECM know if the car is stationary or in drive mode for idle and drive programing.
Old Mar 25, 2024 | 04:34 PM
Scott's 83' Z's Avatar
Car: 1983 Z28
Engine: L69
Oem spark plugs or some other brand? My 83’ ran like crap when I tried other “ better” spark plugs. If you used something else I would go back to OE plugs. Having the same issue with my Ram truck as well.
Old Mar 25, 2024 | 05:59 PM
Vader's Avatar
Good call. However, from the binary files I've looked through, the park/neutral is usually defined as an adder to the base/target idle. Nonetheless, it could result in the overall idle or IAC steps being higher under conditions that wouldn't exist with a manual trans, depending upon how the conversion was done.
online170
Carburetors
May 18, 2008 07:02 PM
92RSB4C
Mar 14, 2006 09:40 AM
MikeDirntRulez
Nov 22, 2005 09:47 AM
HawaiianRS
Apr 6, 2005 05:02 PM
onebad82z
Carburetors
Sep 1, 2002 06:24 PM
