88 ac box on a 87?
Old Apr 27, 2024 | 01:17 PM
Mike Jendrycka's Avatar
Car: 1987 iroc convertible
Engine: 5.0
Transmission: 5 spd
Axle/Gears: 3:45
88 ac box on a 87?
can I use a 88 ac box on my 87? The one on my 87 I am working on is broken. I do have an 88 parts car here that has a nice one, will they interchange? Thanks for any help.
Old Apr 27, 2024 | 02:31 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
Re: 88 ac box on a 87?
yes, the evap may be slightly different but will work.
Old Apr 27, 2024 | 03:03 PM
AFAIK they're all the same.
If the evap is different enough to cause trouble, and your existing one is OK, they're easy enough to swap out.
The usual way these things die is, the lower surface toward the engine, turns to dust, from the heat off of the exhaust, and develop a giant hole down there where you can't really see it. Now's the time to get rid of any of that that's bad and replace it with body fiberglass or the like.
Old Apr 27, 2024 | 06:00 PM
Engine: 5.0
Transmission: 5 spd
Axle/Gears: 3:45
thanks for the info!!!
Old Apr 27, 2024 | 06:01 PM
Engine: 5.0
Transmission: 5 spd
Axle/Gears: 3:45
thank!!
antosh
Jul 17, 2010 04:51 AM
sylentnite
Dec 26, 2007 02:01 PM
JB22
Aug 9, 2006 04:19 PM
Damageincta
May 15, 2004 02:25 PM
360Iroc
Apr 15, 2002 10:23 PM
