Cranks a few times but stops
Old Apr 28, 2024 | 03:45 PM
WyattX_X's Avatar
I have a 1985 Pontiac firebird and when I first got it it would crank a few times but then not crank the rest of the day so I thought it needed a new battery and starter I did that and put them in and it still cranked a couple times and then just stopped cranking and the car still has power. I’ve heard about the neutral safety switch but it’s confusing on why it would kick in after it’s already cranked over a couple times. The ignition is also all busted up I have to use a screw driver to even crank the car so maybe that’s the issue I’m not sure
Old Apr 28, 2024 | 03:59 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Cranks a few times but stops
Can you physically get your hand on the ignition switch rod and force it to crank ?
it could be a misadjusted ignition switch . A lock cylinder is cheap and easy to replace.
Old Apr 28, 2024 | 07:04 PM
WyattX_X's Avatar
I haven’t got my hands on the rod yet bc I’m in the process of getting steering wheel off but I’m waiting for a puller but that’s first on my agenda is replacing the lock cylinder to see if it helps
Kaoticmethod
Feb 9, 2013 05:38 AM
Crossbreed
Jul 11, 2008 10:43 AM
'86 350
Jun 27, 2007 01:31 PM
'86 350
Sep 7, 2006 08:51 PM
