Oil Pressure and Idle Issues
I have an 1989 Camaro RS with a 305. I checked the oil pressure with a manual gauge, and it had a little over 20 psi at idle, put in a new sensor and the gauge works but sometimes has really low pressure at idle after a few minutes of driving. Also when this happens can sometimes have a low Idle as well. Any thoughts? Also I would like to mention its the first time the car has been on the road in almost 5 years.
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Re: Oil Pressure and Idle Issues
Change the oil.Also Small block Chev oil pressure requirement is 10 lbs/1000 RPM, so if you're seeing 20 pounds at idle, that is over twice the necessary pressure. It is fairly normal pressure for a warmed up SBC, but it's over twice the requirement. The oil pressure is sufficient. But change the oil anyway.
squirrelybird
Mar 12, 2001 09:42 AM
