VATS going off whenever I open a door
Old Jun 18, 2024 | 09:08 PM
Wolverine2505's Avatar
Car: 1990 Camaro RS
As I said in the title, anytime I open the driver side or passenger side door, the alarm goes off. Even with the key in the ignition the alarm does not shut off. I have tried disconnecting the battery, waiting, then reconnecting it but the alarm still goes off when I open a door. I have also tried re learning the key but that did not work either.
Would it be better to try and bypass the system, or have it removed completely via a tune?
Would either of these options cause further problems?
Is there a better option?
Old Jun 18, 2024 | 09:38 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: VATS going off whenever I open a door
Vats isn’t hooked to the door switches. Sounds like a aftermarket alarm system.
Nutro
Sep 10, 2023 11:45 AM
G-reg
Sep 13, 2010 08:46 AM
Transambandit
Feb 21, 2010 03:35 PM
Token
Aug 14, 2004 01:27 PM
Error404
Oct 26, 2003 09:19 PM
