Changing to MSD distributor 8362 - or not?
Old Jun 20, 2024 | 12:20 AM
Hotrodder's Avatar
Car: 1934 Ford Roadster
Engine: 350 CSB
Now I have a (China made) Skip White distributor bought 11 years ago.
It works, but when I try fine tuning it with the Moroso weight and spring kit, it all gets either too sloppy, or, to get rid of the sloppyness, I must use too stiff springs for my application, to make the weights swing out and return back as they should.
Will replacing the complete distributor with a MSD 8362 HEI unit make a difference?
I have actually never seen (or held in hand) one of these.
Can I expect the MSD unit to be firmer / steadier when it comes to the mechanical advance mechanism, than the the one I have?
Old Jun 20, 2024 | 10:24 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Changing to MSD distributor 8362 - or not?
Springs can be mixed and matched to achieve a desired timing curve. You can use a heavy with a light spring to get the curve you want.
Nothing wrong with the 8362. Looks like a drop in replacement HEI large cap distributor but built to MSD specs.
Old Jul 11, 2024 | 02:12 PM
leakyz28's Avatar
Car: 88 IROC-Z
Engine: 350 H.O. w/ 113 heads (SUM-8800)
Transmission: 700r4 stage 2 500hp
Axle/Gears: 2.73 Posi Yawn Fest
I personally use that distributor with my 350 H.O. crate engine and it times very well, centrifigual advance mechanism seems very well made an durable, noticably better than what a generic "performance" HEI from amazon gets you (or any chinese made for that matter), I had one and compared them side by side, there's definitely better quality control on the MSD units when it comes to the advance mechanism.
Old Jul 11, 2024 | 04:19 PM
Hotrodder's Avatar
Engine: 350 CSB
Thank you for your answer.
since I made this thread, I decided to try a made in USA GM HEI unit, and came across a used one in working order, that I bought. Haven’t arrived yet.
onthedownlow
May 8, 2013 06:21 PM
25THRSS
Aftermarket Product Review
Sep 19, 2004 02:29 AM
ericoo1
May 4, 2003 04:07 PM
YenkoZ28
May 8, 2002 09:40 AM
