RPM Inconsistency
Old Jul 2, 2024 | 07:10 PM
91RS_Chris's Avatar
Car: 1991 Camaro RS
RPM Inconsistency
Hey everyone, I have been having a tricky issue with my 1991 Camaro 305 RS. For the last few months, it has been presenting an issue typically when going from high RPM’s down to a stop and also at idle. The issue causes the rpm’s to get stuck in a high position and usually the check engine light will come on. It will also pull the car forward while the RPM’s are high. You can be sitting at a stop sign and suddenly the car will want to drag forward. It usually stops as soon as you go through the gears and may not come back, or may do it the rest of the drive. The car is mostly stock with a cam and headers. I have replaced the speed sensor and EGR solenoid. The issue got better but is still persisting. Any thoughts?
Amila
May 29, 2017 02:52 AM
pbtrilogy
Oct 3, 2010 03:59 AM
Beat Fords?
Dec 1, 2001 09:44 PM
