Rough idle seems random !?
Subscribe
Jul 8, 2024 | 01:12 AM
My 92 RS had seemingly idled high one day then just seemed to do so after, I did have a leaking radiator which I replaced today put it into reverse to back up and test drive then the car stalled, died, then Idled lower like normal. It has been running high for maybe a month+. I also changed the spark plugs with the radiator. Is this black magic and has nothing to do with the work I did ?
Also kinda off track would y’all recommend me reading the third gen Camaro Haynes Manuel ?! I bought it and kinda enjoy reading it and am very green so I figured there’s no harm huh ?
Reply 0
Jul 8, 2024 | 10:26 AM
Re: Rough idle seems random !?
Are all your plug wires on the correct plug and fully seated? Any codes?
You could try cleaning your throttle body and IAC it might be sticking
Reply 0
Apr 23, 2025 | 12:59 AM
Quote: Are all your plug wires on the correct plug and fully seated? Any codes?
yes! I actually had a 43 and 33 code I replaced both sensors and I think it all went away I was borrowing an obd1 computer thing from my fathers friend so I wasn’t able to read it again after, BUT I was then able to hone in the distributer, which fixed my idle issue! I believe my faulty knock sensor was throwing everything off (code 43) thank you for suggesting that a while ago!
Reply 0
Subscribe
