Rough and low idle with black smoke
Old May 14, 2003 | 12:31 PM
Athila's Avatar
Car: 1987 IROC-Z Convertible
Engine: 5.7 TPI
Transmission: WB performance auto
Weird stuff! I drove my car fine for a whille and then one morning when I started up the car it idled very rough and it was very low like 400 rpm and black smoke was comming out the pipes. The only thing i did was 2 days before this I have flushed the radiator and replaced the main hoses , also replaced the wiper motor and pump. I haven;t really looked at the problem but before I do i could use some sugestion. Thanks!
Old May 14, 2003 | 12:36 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That would be a rich condition.
My suggestion would be, tell us what kind of motor this is; at least, whether its carb or FI, and maybe what year.
Old May 14, 2003 | 12:45 PM
Athila's Avatar
Engine: 5.7 TPI
Oh sory I forgot about thet lol: it's a 1992 5.7L TPI
Old May 14, 2003 | 12:57 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
OK then...
Sounds like the coolant temp sensor (in the water outlet, where the upper radiator hose goes) got left disconnected.
Old May 14, 2003 | 02:38 PM
Athila's Avatar
Engine: 5.7 TPI
ok i'll look for that but could it also be some kind of vacum problem?
Old May 14, 2003 | 02:46 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No.
A vacuum leak lets in extra air, not extra fuel.
Old May 14, 2003 | 05:53 PM
Athila's Avatar
Engine: 5.7 TPI
I checked but i did not see the sensor. I asked around and someone told me that they did not have those sensors for a 92. Also a weird thing happened too. I started the car now and it run fine for about 3 min then it started doing it again. My car is an 87 iroc but the engine is a 92 tpi. Don't know if it makes a difference. Thanks!
Old May 15, 2003 | 04:42 PM
RageSK813's Avatar
My car had a real bad idle too with the black smoke. But mine would dies at me occasionally when I came to stops. What I did was change the O2 sensor which helped a little so I cleaned out the throttle bottle with some Carberator Cleaner and since then it has been working great. So I suggest you to try clenaing the throttle body first and see if that helps.
Old May 16, 2003 | 12:15 PM
Athila's Avatar
Engine: 5.7 TPI
I checked the coolant sensor by unpluging it, and the car ran perfect. I plug it back in and it starts running like crap so I guess all I need to do is to replace the coolant sensor. Weird problem this sensor created. Thanks for all the help!
Fronzizzle
Aug 17, 2015 02:52 PM
perZ
Aug 15, 2015 01:17 PM
squiggy2
Aug 9, 2015 09:30 PM
