No fuel from injectors TBI; tested everything I know
Old Jul 15, 2024 | 12:40 PM
Beaz's Avatar
I have read about every post out there for common problems to troubleshoot when the injectors are not firing, but I'm at a dead end. Here is what I've done:
Replaced sending unit and fuel pump because they had failed
Tested:
Both injectors read 1.5ohms
Both injector wires have 12 volts
Both injector wires flash with noid lights when cranking
TPS voltage is correct around .5V idle and ~4.5V wide open
Fuel pressure at TBI is 12psi
Could it be the fuel pressure regulator? Please advise.
Old Jul 15, 2024 | 12:45 PM
Re: No fuel from injectors TBI; tested everything I know
Does it have spark? Test by pouring some fuel down the throttles and trying to start it.
Old Jul 15, 2024 | 01:15 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
if this has sat unused for a year or more,injectors are probably stuck-a firm bump on top the injector between the terminal pins with a hard,blunt object usually gets them working again
Old Jul 15, 2024 | 01:18 PM
Beaz's Avatar
Yes... it starts and runs when there is fuel dumped into the throttle body
Old Jul 15, 2024 | 01:20 PM
Beaz's Avatar
I'll try this and let you know.
Old Jul 15, 2024 | 01:25 PM
If they're that bad, just "rebuild" them.
Disassemble, soak in lacquer thinner for a few hours, reassemble with new paper & rubber. No-brainer. The kit is like $15 or some such. Even if you disturb the injectors into working mechanically, cleaning all the crud out of them will make a YYYYYUUUUUUUUUJJJJJJJJE difference in how it runs.
Old Jul 15, 2024 | 01:28 PM
Beaz's Avatar
That did it... I've been trying for more than a week to troubleshoot this thing and a couple of taps fixed it!? Thank you for the suggestion!
Beaz's Avatar
I'll do that. Thank you!
BIGJPAYNE
Sep 22, 2010 05:06 PM
irishhockey34
Nov 6, 2009 06:44 PM
Dubya
Apr 29, 2008 01:28 PM
senatorcbp
Sep 15, 2005 09:15 PM
Brent
Jun 17, 2003 11:29 PM
