Need help with Lt-1
Old Aug 20, 2024 | 04:48 AM
Mspangler's Avatar
Car: 1991 Camaro RS
Engine: 5.7 Lt-01
Axle/Gears: 3:28
Need help with Lt-1
So my camaro has a 1996 Lt-1 out of a corvette. I know the cam has the distributor gear still, I can only find one aftermarket intake that lets me run a distributor. I want to run a blower, but can't find a a base for one for the Lt-1 with a distributor port. Could I swap heads that would let me run a different intake? Or are the heads a different bolt pattern to the block as well?
Old Aug 20, 2024 | 07:18 AM
Vader's Avatar
Re: Need help with Lt-1
If the desired is to use a SBC engine with a top-mounted PD blower, the easier path may be to start with a Vortec style block and heads instead of the LT1/4 version. In addition to the intake base fitment and moving the distributor from the front to the rear, the cooling system might also bite back at you.
Old Aug 20, 2024 | 08:57 AM
Mspangler's Avatar
Car: 1991 Camaro RS
Engine: 5.7 Lt-01
Axle/Gears: 3:28
Yeah I figured I'd have to switch blocks completely, just was hoping I could use the one I had. Thank you
Brad-Drake
Jan 26, 2014 05:19 PM
DontBlnkBadWolf
Nov 23, 2008 06:17 PM
diablizzard
Nov 4, 2007 04:24 PM
Ricco
May 22, 2007 07:54 PM
S10Wildside
Jul 14, 2002 11:12 PM
