My car won't start, opinions appreciated!
Old Jan 23, 2002 | 06:01 PM
BrianB's Avatar
I am assuming it's just the starter. The battery isn't dead and the alternator is charging fine. It has been rough starting like it isn't getting enough UMPH to start, but just enough to get it to start. It did this a few times and finally just now, nothing! Turn the key and nothing, no clicking nothing. Could it be the fuel pump? The car was running fine and normal as it usually would when I would get it to start. I didn't get a check engine light while driving either, checked the codes and nothing. Your opinions are appreciated, thanks!
Old Jan 23, 2002 | 06:05 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I would say starter Or maybe a bad ground to the battery? Not sure if a bad ground would cause a hard start.
Old Jan 23, 2002 | 06:14 PM
BIGJsTA's Avatar
If theres no clicking sound at all it's usually the battery, if your sure the battery, and the terminals as well are good (try cleaning the connections maybe) you might look at the connections at the starter and the solenoid, if all that's ok then it's the solenoid i think, cuz if it's the starter i beleive the solenoid will still give that 'click',...it could possibly be the ignition too. A good way to check is see if your lights work, if so, not the battery
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
