roller cam assembly lubing...
Old Jan 23, 2002 | 07:03 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
When I was at tech we just covered the entire flat tappet with assembly lube and put in the block.
I heard I should be using assembly lube on the lobes and 30w on the journals (?). Is that any different for a roller?
I should soak the lifters in oil and squish them so they prime, right?
Old Jan 23, 2002 | 07:33 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I didn't think roller lifters had to be soaked in oil in order to pump up. Or am I thinking wrong.
Old Jan 23, 2002 | 07:46 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
comp recommends cleaning the lifter to remove grease
that is shipped with. and the soaking in 30w for 30mins.
This is not to soak oil in to the lifter but for the roller bearings in the bottom.
Old Jan 23, 2002 | 08:03 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
thanks...that about the cam?
Old Jan 23, 2002 | 08:39 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
just lots of oil for the cam.. all over.
that will do it..
Old Jan 24, 2002 | 06:01 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Right... oil on the lobes is fine.
Roller lifters don't "pump up" any differently than flat-tappet lifters do. You should always wash the cam and lifters thoroughly in clean solvent to get rid of the schmutz from the mfg process, and then soak the lifters in oil to make sure all their moving parts get lubed, and to get some oil into their little oil chambers so they don't clatter so much for so long at initial startup.
angel2794
Sep 8, 2015 06:22 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
z28guy134
Sep 1, 2015 11:50 PM
masonta
Sep 1, 2015 06:40 PM
