Headlight Aiming
Old Jan 23, 2002 | 08:45 PM
scanman717's Avatar
Car: 92 Z/28 Convertible
Engine: LB9
Transmission: Mad Dog Auto 700R4
Headlight Aiming
Can someone give me a quick and dirty to getting fairly good headlight aim?? The service manual only tells you to use a special tool, and I seem to recall that the "shadetree" way was to park it so far from a wall and measure, etc. etc.
Troy
Old Jan 23, 2002 | 10:28 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Pull up at right angles as close as you can to a wall and mark the center of the spots your lights make on the wall. Back up straight about 25 feet and check the spots again. The marks for the low beams should be about 1/2" to 1 1/2" lower and 2" to the right of where they were before, and the high beams should be about 0" to 1/2" lower and 2" to the right.
Linson
Oct 1, 2015 09:50 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
