Need fan ideas
Old Jan 23, 2002 | 10:03 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Need fan ideas
My car overheats at idle with a stock 5 blade fan and thermostatic clutch. I haven't checked the clutch to see if the fluid has leaked, which might be the problem, but if that's not it, what should I do? Should I try a stock 7 blade fan, or maybe a steeper pitch aftermarket fan? I don't really want to convert to an electric fan, but that's a possibility too. Even if the clutch has just leaked, should I just replace it, or try something else?
Old Jan 24, 2002 | 09:53 AM
Damon's Avatar
That fan should be PLENTY for keeping your engine cool. If the viscous clutch is of unknown age, jsut replace it. That sucker should be moving a TON of air when the rad is hot.
If that doesn't help your next part to replace is the water pump (might as well do the stat while you're at it) and them finally the radiator. This is due to the cost of the parts- cheap stuff first and the difficulty of perfectly diagnosing the true cause of the overheat. A bad water pump and a bad rad act very similarly.
Of course, all this assumes that the engine is running acceptably at idle. If you've got mechanical or massive tunign problems this all goes out the window.
Old Jan 24, 2002 | 11:18 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The water pump and rad are both new so they're not the problem. It stays cool enough as long as its moving anyway. I'll try heating the clutch with a torch and see if it engages.
Old Jan 24, 2002 | 11:41 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
What about your radiator cap? Replaced it lately? Also if your timing is off or you're running lean then your car will overheat. Make sure you don't have a leak around the thermostat, the loss in pressure won't help.
Old Jan 24, 2002 | 12:14 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The cap's new with the rad, no leaks anywhere.
Old Jan 24, 2002 | 12:47 PM
Hellraiser's Avatar
overheating
Do you have a fan shroud? If so check to see if it is damaged in any way, and that its the proper size for your application.
I had a similar problem with a built 350 in my old 86 camaro...
It ran about 230 in the summers in NY, but when i moved to florida i found the car was overheating at idle constantly.
Turned out all i needed was a shroud (id never installed one)
to help move the air straight through the radiator.
Old Jan 24, 2002 | 12:59 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes it has the correct shroud.
Old Jan 24, 2002 | 01:13 PM
82camaro's Avatar
Car: 82 camaro SC
If the fan clutch is over 5 years old, replace it. Even if it kicks in when you heat it, it might not be kicking in completely. I had this exact problem with my 91 Jimmy. The fan clutch would kick in and make the fan pull air--just not enough air. With the new clutch (cheapie lifetime from autozone) I can idle with the AC on, in town, when it's really hot out.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Jetmeck
Sep 4, 2015 12:29 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
