Fuel Pump Running with No Key
Old Dec 30, 2024 | 03:56 PM
pikapp255's Avatar
Car: 1987 GTA
Engine: 383 stroker slp bored runners
Transmission: 700r4 corvette servos
Hoping someone on here can help. Let the GTA sit for about 18 Months. Went to start it back up after plug change and oil and a new battery. Completely restored with new motor less than 2K miles on it. Once the new battery installed it immediately started the fuel pump priming and wont stop. No key, unplugged the relay and Oil Switch and it still runs when the battery is connected and it wont start. Any ideas of what is causing this? Never had any issues with the car since the New 383 Stroker put in with SLP TPI. Still running stock ECM with custom tune.
Old Dec 30, 2024 | 06:09 PM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Re: Fuel Pump Running with No Key
Try replacing the relay. Take a fan relay and put it in there and see if that fixes things
Old Dec 31, 2024 | 10:22 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Sure you unplugged the correct fuelpump relay?
Old Feb 3, 2025 | 04:29 PM
pikapp255's Avatar
Car: 1987 GTA
OK, so the relay finally came in. I replaced it and it's still running while the key is off. Also, for some reason now the fan is running as well? Any ideas? Car wont start but it is getting fire.
Old Feb 3, 2025 | 07:04 PM
Vader's Avatar
Verify whether the FP relay is receiving power to its operating coil when the ignition is turned off - most likely the dark green/white wire. If there is power, check that the ignition switch is functioning, and actuating ALL the way in both directions. The sector and linkage rod in the steering column can get a little fidgety.
If that's not the issue there may be a problem at the C100 connector. Moving, flexing, crushing, twisting that connector and harnesses during an engine exchange can cause many problems there, as can moisture and corrosion.
igende
Nov 12, 2015 05:03 PM
Speed Racer X
Jun 28, 2012 01:48 PM
68Strat
Feb 3, 2010 04:35 PM
gapimpin
Nov 28, 2007 06:16 PM
stuart
Nov 13, 2003 11:43 AM
