PCV - A/C Delco 06487779 vs. Others
Car: 1988 IROC-Z
Engine: L03 to L05: 350 TBI
Transmission: MD8: 700R4
Axle/Gears: GU2: 10 bolt/2.73
All,
I've ordered an A/C Delco PCV valve as I've always had better results going OEM vs. China or equivalent. My current knock off PCV rattles but the barrel that slides up and down is very loose and unpredictable whether or not it will seal under vacuum and release during throttle and load. I can apply vacuum with random results.
Has anyone else experienced similar results with a bad, out of the box knock off brand like a STANDARD MOTOR PRODUCTS V178 ?
-Chris
-Chris
Car: 91 TA Vert WS6-94 TA Vert
Engine: 5.0/5.7 LT1
Axle/Gears: 2.73-3.42
Re: PCV - A/C Delco 06487779 vs. Others
All,
I've ordered an A/C Delco PCV valve Amazon.com: ACDelco CV774C (06487779) Positive Crankcase Ventilation Valve : Automotive as I've always had better results going OEM vs. China or equivalent. My current knock off PCV rattles but the barrel that slides up and down is very loose and unpredictable whether or not it will seal under vacuum and release during throttle and load. I can apply vacuum with random results.
-Chris
-Chris
Amazon can't be trusted not to be counterfeit unless its from one of they're stores, like the "Delco store."
If the part is just in what you might call "general Amazon inventory," im not buying it.
69 Z11
Sep 14, 2023 11:40 AM
