Vacuum T part number
Old Jan 17, 2023 | 05:25 PM
BG1959's Avatar
Car: 1989 IROC-Z, 1970 Camaro SS
Engine: 5.7
Anyone know where I can get a replacement for this vacuum T. Would a ordinary T fitting work in it's place. It broke when I tried to remove a vacuum line. Very brittle.
Thanks in advance
Old Jan 17, 2023 | 05:40 PM
BG1959's Avatar
Engine: 5.7
Thanks in advance
Old Jan 17, 2023 | 09:29 PM
tajefe's Avatar
Re: Vacuum T part number
AutoZone carries them in AC Delco I wouldn't recommend the Doorman its junk.
Should be this and its a check valve not just a tee
ACDelco Canister Purge Valve 15-50568
Old Jan 17, 2023 | 10:54 PM
BG1959's Avatar
Engine: 5.7
thanks for that. I had just found the dorman on Amazon and ordered it before I saw your message. I'll see if I can cancel it.
Old Jan 18, 2023 | 01:26 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
It's actually a check valve. Closes off manifold and opens up the line to the vacuum reservoir when you step hard on the throttle.
Old Jan 18, 2023 | 02:35 PM
tajefe's Avatar
This is exactly why I gave the AC Delco part number, the Dorman is junk. Ask me how I know.
Old Jan 21, 2023 | 12:53 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I have used the Dorman one many times without any issues. I bet the AC Delco one comes down the same assembly line in China.
Old Jan 21, 2023 | 10:33 AM
tajefe's Avatar
I'm glad the Dorman has worked for you!!!!
However OP just read the reviews on that particular part and it would suggest why i would not recommend. Well that and I bought one at my local store put it on and it would not do its job. Had them order the AC Delco for like $3.89(was less $ than the Dorman just had to wait overnight) and worked like intended. And no they dont come down the same line and look totally different, both still probably made in China though
87iroz-c
May 14, 2021 03:36 AM
jworks
Oct 2, 2017 04:12 PM
dynodanmanda79
Mar 10, 2010 08:03 PM
jfreeman74
Jan 18, 2003 05:44 AM
