DEAD 350 880 block
DEAD 350 880 block
HI all ive spent god knows how much money on this engine
1st off started engine with fi tec 3004 installed !
reved for the hills headers turned white almost see through
found no reason for this ! sent fitec unit back to fi tec
thay made sum ecu mods ! nothing wrong with it !
so back on it went same thing again
fed up with this fitted a edelbrock 600cfm 4 barrel it started it ran did not rev but filled the garage with blue smoke.
so apart it came
oil everywear on top of pistons inlet ports exhast ports everywhear
heads have been sent to machine shop told that no good not cost effective to repair
cam has grooves worn in it
lifters have strange wear patern on sides of bottom of lifter wear rolled pin goes through
crank has scoring and sump full of thick grey colored muck in bottom
strange wear pattern on bores and sum scoring
when i built the engine i fitted a high volume melling oil pump .has this emptied the sump and whiped my engine out ?
ive read sum 880 blocks wer not fully machined for roller cams ?
block is 030 bored how far can this be bored ?
any help greatfuly receved
ow icing on cake just purchased a edelbrock pro flo 4 xt for it befor finding it was dead
so happy .NOT
so apart it came
so happy .NOT
Re: DEAD 350 880 block
crank has scoring
[Sold] Rebuilt 350 Long Block
TKO500
Dec 16, 2017 03:21 PM
anesthes
Jun 11, 2010 05:18 AM
