84 Trans-Am Ignition Coil Question
Car: 1984 Firebird Trans-Am
Engine: 305 HO
Transmission: Stage 3 Built 700R4
Axle/Gears: Moser axles+3.73 gears+Auburn Posi
Im trying to find out if my 1984 Trans-Am (original 305HO) has a remote ignition coil or if its in the distributor. Admittedly, Im very ignorant when it comes to things like wiring and ignition systems. I have a buddy wanting to help me tune my car, he said to get a performance ignition coil before we tune it, but Im not sure where the coil is in my engine bay. He looked briefly, also at night, and couldnt find it.
Where is the ignition coil? Or is the ignition coil integrated into my distributor? (Be nice, Im new to old systems)
Re: 84 Trans-Am Ignition Coil Question
It had the original-style HEI with the coil in the cap. pop the plug wire retainer ring off if it still has one, pull the 2 screws on the very top, lift off the big square-ish cover, there it is. It's not exactly "integrated into" the distributor butt it's kinda that way.
Engine: 305 HO
Don't think so. At least all the Mallory ones I've ever had used an external coil.
Note that I spoke initially of what it CAME WITH, not what it HAS.
Photos might help.
Photos might help.
Engine: 305 HO
I have an older style Mallory HEI distributor. I cant get a picture of the one on my car at the moment but here is one that looks to be similar, if not the exact one:
Looks, to the eye, like a coil-in-cap design, for whatever little that's worth.
Check w Mallory for more details. Although, Holley appears to be dismantling any kind of support for all their older stuff, same as they do to all the brands they acquire; so if you need parts or anything, you might be out of luck.
