Returning to TPI
Old Mar 16, 2025 | 11:26 AM
mmckey2's Avatar
Returning to TPI
Does anyone have tips for returning to TPI on engine? I swapped to a carb and vortec heads 20 years ago. Now I am piecing together tpi parts to swap back.
Old Mar 16, 2025 | 11:44 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Returning to TPI
Might just want to ask questions as you go, did you get a scoggin dicky tpi base ? What cam and injectors are being used?
Old Mar 16, 2025 | 11:58 AM
mmckey2's Avatar
I have a SDPC base being ported as we speak. Planning to use AS&M runners, 30lbs injectors, 52mm TB, Comp Cams XFI 268 Cam (my block is non roller). Heads have roller tip rockers and high lift springs. Think I have the 2460 hooker headers if I remember right.
Old Mar 16, 2025 | 12:24 PM
Engine: Lb9
Transmission: M20
When you break in the cam might run a light pressure spring. Seen so many stories about flat cams lately. COMP Cams DLC High Energy Hydraulic Lifters 812D-16 are worth the extra money. Or if it’s already broken in, sounds like good components if the injectors are a good name not cheap china ones.
Old Mar 16, 2025 | 03:43 PM
mmckey2's Avatar
Appreciate the recommendation on the lifters. I will be buying a brand new XFI-268 cam. I have a XE-262 in it now with the carb. From my research, I think the LSA is too low on it for tpi tuning.
Stephen
Aftermarket Vendor Review
30
Aug 13, 2010 11:37 PM
TXFBODYGUY
Sep 15, 2009 01:41 AM
BuckeyeROC
Aug 30, 2003 02:29 AM
T/A_SXracer
Jan 17, 2003 08:33 PM
