L05 Swap from TBI to Carb
Car: 1992 Camaro RS
Engine: 350 SBC
I have an L05 350 that I swapped from TBI to carburetor. It is an edelbrock 1406. Ever since I did the swap, however, my engine has been running at 4K RPM at idle in park gear. I made sure the gaskets are al completely sealed, there are no gaps whatsoever, but I’m still getting bluish smoke out of the exhaust and high rpm’s. What’s going on?
Re: L05 Swap from TBI to Carb
What’s going on?
Car: 1992 Camaro RS
Engine: 350 SBC
Is there any way to do the valve seals without pulling the heads? Also it’s an aftermarket tach hooked up to the distributore itself, so I think it’s reading right.
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Does the engine sound like it's revving 4k RPM?
The aftermarket tach is probably set for 4 cylinder mode but a 2k idle would be to high too.
A L05 sitting in Park or Neutral with the throttle WIDE EFFFFING OPEN will barely do 4k. I think either it's defective or it's set up wrong. Especially if it PEGS the instant you actually hit the throttle. If it idles at 4k, and you go to take off from a stop, should read AT LEAST 7000, if not more. Altogether impossible for a TBI motor. Which you didn't mention that, leading me to suspect that ... maybe ... it does.
Car: 1992 Camaro RS
Engine: 350 SBC
yes. when it was idling with the TBI on it was reading around 900, and it was relatively quiet. as of right now its super loud from both the engine itself and the exhaust.
