Possible spark plug issue
Old Mar 26, 2025 | 08:09 AM
Vhanta97's Avatar
Car: 1984 Camaro Berlinetta Starship Ed.
Engine: Worn out SBC 305 5.0L V8
Axle/Gears: Stock
So I got new spark plugs for my 305 and noticed that the length between the threads and the nut on the new ones are shorter than the ones I pulled by about a centimeter. Would that cause any issues or should I take them back and exchange for similar spark plugs?
Old Mar 26, 2025 | 12:09 PM
Re: Possible spark plug issue
Depends.
1 cm is ALOT. A YYYYYYYYYUUUUUUUJJJJJJJJJJE LOT in case I wasn't clear about that. Since the RIGHT plugs for stock heads have about 1½ cm of threads, sounds to me like maybe you had the wrong ones in there to begin with.
What heads are on it? What part # plugs did you take out? What part # did you put back in?
Old Mar 28, 2025 | 12:32 PM
Vhanta97's Avatar
Axle/Gears: Stock
Depends.
So I figured out what went wrong. I can still use these spark plugs, the threads are exactly the same in pitch and length. It's the bit of shank between the hex nut and the thread that's different. The new plugs will just put the cable boots closer to the heads, which in theory won't cause any issues.
Abubaca
Mar 15, 2017 09:19 PM
musclecar70sfan
Aug 12, 2009 07:12 PM
thirdgenlover
Oct 26, 2006 02:05 PM
pre
May 11, 2004 09:01 PM
FastElectrics
Jan 4, 2002 09:49 PM
