Unplugged O2 sensor to stay Open Loop - water pump failure
Old Apr 11, 2025 | 05:58 AM
Smykster's Avatar
Car: 1991 RS 305TBI
I’ve been chasing shakey idle in my 91 tbi. Changed EGR, IAC, CTS, plugs, wires, rotor and cap. No change to idle.
seems to only happen once the car is warmed up so I figured it only happening once it goes from open loop to closed.
I decided to test that theory on a short 5 minute drive by disconnecting the O2 sensor. Car ran perfect the whole drive. No shaking.
when I parked and got out, coolant was pouring out from under the car, looks like it was coming out directly at the water pump from the weep holes.
is there any way disconnecting the 02 sensor for a short drive could have caused this? Or a crazy coincidence? Temps were fine the whole time.
Old Apr 11, 2025 | 07:54 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Unplugged O2 sensor to stay Open Loop - water pump failure
Coincidence only. Perhaps the O2 sensor itself is bad.
Old Apr 11, 2025 | 08:53 AM
Smykster's Avatar
Car: 1991 RS 305TBI
I really hope so. I’m was going to replace it today but now I have a water pump job to do first!
Old Apr 11, 2025 | 09:54 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Would really get ecm data. Unless the 02 is stuck at .450mv it’s probably doing its job of reporting.
Old Apr 11, 2025 | 12:46 PM
Smykster's Avatar
Car: 1991 RS 305TBI
yeah I didn’t think of that. All I proved was that something is wrong at closed loop. Does t mean it was the 02 sensor. (Fingers crossed that it is).
if that doesn’t solve it, I’ll done some research on how to get that data from the aldl connection.
Old Apr 11, 2025 | 01:43 PM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Geeze, tough problem. I'm looking thru the list of things that can go bad, and there's not a whole lot in there. Can understand why you were considering the O2. Perhaps checking all your ground connects and make sure all you wiring is intact, starting with engine ground.
https://www.thirdgen.org/forums/v6/4...ml#post3801073
Old Apr 16, 2025 | 09:15 AM
Smykster's Avatar
Car: 1991 RS 305TBI
thanks, this is great and something I definitely have to do.
Old Apr 17, 2025 | 04:35 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Hows the fuel psi when it warms up?
Old Apr 25, 2025 | 04:45 PM
Smykster's Avatar
Car: 1991 RS 305TBI
that’s a great question, I too was wondering if the pump might be failing. I don’t know the fuel pressure. I wish these cars had a shrader valve for fuel pressure.
if I put in a fuel pressure tester, should I do it just after the fuel filter, or closer to the throttlebody in the engine bay?
also, when it warms up, the oil pressure seems like it dances around. It’s always in a good range, but the needle is jumpy. Not sure if that is normal or not.
aammcc
Feb 15, 2010 05:55 PM
scotte
Jun 3, 2007 12:09 AM
DON 88T/A
Nov 12, 2005 01:09 PM
jo88gta
Jul 13, 2003 04:16 PM
