Which valve seals???
Old May 1, 2025 | 07:59 PM
Karl_Schuler's Avatar
Car: 1985 Trans Am
Engine: Barely
Transmission: Blown
Axle/Gears: I guess?
Hey guys, just a real quick question.
I'm gathering all the parts I need to "Rebuild" my 1985 305 TPI and had a small dilemma.
I ordered a fel-pro head gasket set which includes new valve stem seals, and I ordered an additional set of enginetech valve stem seals.
The fel-pro set comes with 2 sets of seals
A set of these labeled as intake
And a set of these for exhaust
The ET kit comes with 20 seals in the same style as the blue one up top.
Intuition is telling me to use the blue style for both intake and exhaust but I wasn't sure if there was a reason not to.
Old May 1, 2025 | 08:21 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Which valve seals???
You can use a standard seal on the exhaust, probably better than a umbrella seal.
Old May 1, 2025 | 09:26 PM
Car: 1985 Trans Am
Engine: Barely
Transmission: Blown
I'm assuming by standard you mean the blue reinforced seals?
Old May 1, 2025 | 09:37 PM
The blue seals are the "positive" type; they grip the valve guide and stay put, and the valve slides up and down through them.
The others are "umbrella" type. They do exactly what the name sounds like: they stay stuck on the valve, and ride up and down along with it, and to the extent that luck is on your side, keep oil from dripping down the valve stem and onto the guide. USELESS AS **** ON A CHICKEN.
So yeah, use the blue type on all 16 valves. The reason FelPro doesn't spec em that way is because of the heat of the exh valve guides, and potential warranty problems. Regardless, they're still a couple of orders of magnitude more effective than umbrellas. You can buy a half-set of em by themselves if you don't have enough.
Old May 1, 2025 | 09:45 PM
Car: 1985 Trans Am
Engine: Barely
Transmission: Blown
Understood, I appreciate the info!
gta88 flamered
Mar 6, 2016 06:49 PM
kevsugly
Oct 12, 2007 09:30 PM
JeffD
Feb 19, 2006 08:29 PM
IRACE87
Sep 12, 2005 06:27 PM
jayman350
Mar 10, 2002 10:25 PM
