Tests
Old Jan 24, 2002 | 03:07 PM
Corry's Avatar
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
Tests
Alright, I need some simple tests for u-joings and wheel bearings. If necessary I can jack up one end of the car. I think I can also get underneath the car for a small amount of time at an oil change place as per vaders suggestion. Now I just need to know what I am looking for.
Any info will be good
Corry
Old Jan 24, 2002 | 03:31 PM
rezinn's Avatar
If they are bad you'll most likely hear it or feel it when you drive and turn. If you even suspect they are bad, I'd just change them. You don't want to be driving with bad wheel bearings, and this stuff is relatively cheap anyway.
Old Jan 24, 2002 | 06:30 PM
1984Firebird502's Avatar
To test u joints. Hold the drive shaft in one hand and the differential yoke in the other and turn opposite of eachother. ANY ANY ANY movement is bad. ANY. The same goes with the front U joint with the tranny yoke. You can normally tell worn U joints if when you put it into drive or reservse, it make a big clunk sound. I think the U joints were my problem, but turned out to be the WHOLE rear end.
Linson
Oct 24, 2025 02:00 PM
RedLeader289
May 28, 2019 01:47 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Eric-86sc
Sep 28, 2015 11:37 AM
