Compressor part
Re: Compressor part
If it's that bracket you're asking about, junkyard.
Very eeeeeeezzzzy to make something that works perfect. A piece of bar stock for example.
Re: Compressor part
able to run it
Would you LIKE IT? would it LAST? would it be RIGHT? those are WHOLE OTHER matters.
Make a efffffing bracket out of a piece of about 1/8" x ¾" strip stock; drill 2 holes in it; put a Z-bend in it; and bolt it to the intake manifold where that stock bracket would go (below the throttle linkage) and the hole on top of the big bracket. Too simple.
