power steering isn’t lining up
Old Jun 30, 2025 | 02:20 PM
jjosb77's Avatar
i got a sbc 400 for my 85 camaro i took the power steering and ac bracket driver side out of a donor car and im puting it in the main car right now. i bolted everything up and flipped the header bolt to put on the ac bracket on the driver side. but when everything is bolted up the power steering isn’t aligned with the bottom pulley.
am i doing anything wrong why isn’t it lining up?
Old Jun 30, 2025 | 02:47 PM
Re: power steering isn’t lining up
Not sure what this means. Doesn't sound right at all though.
Here's what the brackets, on a header, on a 400, should look like. Eeeeeezzzzzyest way is, to use the stock stud things for the 2 front DS manifold bolts, and make a spacer out of something - ANYTHING, like maybe water pipe or some such - to make the sum of the header flange plus the spacer, equal to the thickness of the manifold. The pic speaks for itself.
armybyrd
Sep 28, 2023 12:16 AM
neilcase
Feb 12, 2022 06:44 PM
maroe624
Jan 26, 2019 10:51 PM
85ricekillingta
Feb 17, 2003 10:41 PM
