Ignition coil sparking while not running
Old Aug 1, 2025 | 10:14 PM
allos's Avatar
Car: 89 GTA, 84 T/A
Engine: L98 stock, Carbed 350
I have an 84 running a non-computer controlled, vacuum advance distributor.
The coil is sparking while the car is off, with the key in run.
I did leave the key in run on accident for a couple of days, long enough the battery drained.
Is this likely a damaged ignition module?
Old Aug 1, 2025 | 10:21 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Ignition coil sparking while not running
It sounds like you should check power wire to the hei. If hot when key is off you could have damaged ignition components. The cause might be misadjusted or bad ignition switch on top of the column.
Old Aug 1, 2025 | 10:26 PM
allos's Avatar
Car: 89 GTA, 84 T/A
It doesn't do it with the key off.
Its doing it with the key in run, but the car is not running.
Unless that is normal, and I somehow never noticed it before.
Old Aug 1, 2025 | 10:28 PM
Engine: Lb9
Transmission: M20
The coil should never give out spark unless the engine is cranking or running. My first guess is icm since the pu coil isn’t being triggered.
Old Aug 1, 2025 | 11:23 PM
allos's Avatar
Car: 89 GTA, 84 T/A
That fixed it.
Thank you.
GnarlyBird
Jan 13, 2025 09:01 PM
GodSpeedGTA
Oct 13, 2006 10:10 AM
Flameredroc
May 19, 2003 08:22 AM
FstBrd6point3
Mar 8, 2002 03:59 PM
