CVR Mini Starter
Old Aug 24, 2025 | 02:13 PM
CHCKLS's Avatar
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
CVR Mini Starter
Mini starter was installed about 30 years ago or there about to replace the factory starter. At the same time a ford solenoid was also installed to help with he "heat sink" issues the factory starter was experiencing. I am assuming that the blue wire in the picture can be removed ( I honestly don't remember doing this myself) since the ford solenoid is being removed. Swapping engine harnesses from 89 to 91 year. Should be able to connect ignition wires to the small terminal and the battery cable to the large terminal, correct?
Old Aug 24, 2025 | 02:42 PM
ratfink6923's Avatar
Car: 15 Ram, 88 IROC, 92 RS
Engine: 5.0
Axle/Gears: 3.42 (4th Gen)
Re: CVR Mini Starter
Correct.
sahlomonic
May 1, 2017 05:01 PM
Galaxie500XL
Dec 30, 2015 09:59 AM
mattheat
Nov 25, 2007 07:00 PM
saliger64504
Apr 17, 2007 01:31 PM
