Porting 113's
Old Feb 16, 2026 | 11:58 AM
  #51
skinny z's Avatar
Re: Porting 113's
More from Steven Magnotti.
File Type: docx
Old Feb 16, 2026 | 12:29 PM
  #52
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Re: Porting 113's
Thanks for posting more. Vizard doesn't like widening the pinch point....oh well. Too late. I was only able to get the CSA of the pinch point up to 2.0" when the wall got as thin as my comfort level (~1/16"). I think on a 400, I need not worry about velocity and tq. Ha ha ha.
I was surprised how long it took to do the pinch point...and get it blended smoothly before/after the cut. It was more tedious than it at first, appears.
I already laid back and blended the ridges outside the valves, that's done. I think I'm in about as good a shape as I can get w/the stock valves....once I get a proper valve job done. Just need to do two more pinch points on this first head.....then do it all over again, on the second head.
Old Feb 16, 2026 | 06:07 PM
  #53
Engine: LT1, L400
Re: Porting 113's
Welp.. I'm done....DOOONE, with one head. Time to start the next. Sure was hoping that I could find a flow bench for a before and after, but not in UT, I guess.
Look at this junk....
Old Feb 16, 2026 | 10:45 PM
  #54
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Porting 113's
That is crazy! The ZZ4 113 heads were far, far, far cleaner castings that that. It is a miracle that tired L98 in your Kart made the kind of HP and TQ it did especially the power it had with the SuperRam.
Old Feb 17, 2026 | 02:57 PM
  #55
Engine: LT1, L400
Re: Porting 113's
I totally agree. I think the way they left those bowls is NUTS!....and I also agree that I can't believe the thing hit 289/375 wheel, with those ports!
....and everything else that was "wrong" with that junk!
Old Feb 17, 2026 | 09:25 PM
  #56
skinny z's Avatar
Re: Porting 113's
I'm not sure if that's not entirely true. I believe he's referencing, in his Vortec video, how enlarging the pushrod pinch (which I understand to be the MCSA of the port) does little if the valve diameter and throat are undersized. He hadn't IIRC, addressed the form in the bowl or the throat beforehand.
I think this is why the number one move with these 113 heads is to increase the intake valve diameter to 2.00" from 1.94". Then go for a 90% throat diameter of ~1.75". Now we're up to 2.40 in² below the seat.
If the previous throat came in at 80% of the 1.94" valve, the area is 1.89 in². Opening up the pinch will do little, or worse, if there's bottle neck below the valve seat.
Keep in mind that the ideal MCSA (in a simplified way) is a function of the bore, stroke and RPM.
This is how it's been explained to me, or rather, the wider forum audience, when having these discussions at engine building websites.
More 2 cents...or 1.46 cents CDN.
Old Feb 18, 2026 | 02:36 PM
  #57
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: Porting 113's
I don't think I've ever seen anything quite like that.
Old Feb 20, 2026 | 08:32 PM
  #58
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Porting 113's
Yup, seen a few sets just as bad..
Old Feb 20, 2026 | 08:55 PM
  #59
Engine: LT1, L400
Re: Porting 113's
Nuts! I can't believe you don't hear more about it on the 'Vette forums...or where ever. I mean...that has GOT to be some low hanging fruit right there!
Black_TA
Nov 1, 2016 06:07 PM
affliction1
Sep 18, 2011 05:40 PM
daves12secV6
Jun 25, 2007 09:01 AM
Berlinetta
Oct 1, 2004 07:37 PM
