Headers & Flexible dip stick
Old Mar 4, 2026 | 03:10 PM
decurl's Avatar
Car: 1984 Camaro Z28
Engine: 305 H.O.
Hey Guys,
I am installing headers on my 84 Z28 and need to install a flexible oil dipstick to work with the headers. Are there any recommendations on a specific manufacturer and part # you guys have installed that worked? I contacted Lokar and they indicated they don't have one for my engine. I find that hard to believe and will keep asking them but always seem to get better advice on thirdgen.org than from the manufacturers.
Thank you!
Old Mar 8, 2026 | 02:21 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Re: Headers & Flexible dip stick
Lokar 100 percent does. I have one. What engine do you have? I have a modded 350, the one that came with my car and it works flawlessly
LOK-ED-5001 CHEVROLET Lokar ED-5001 Lokar Flexible and Machined Engine Dipsticks | Summit Racing
Old Mar 8, 2026 | 02:38 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
I also have the lokar one.
Old Mar 8, 2026 | 07:39 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Lokar here as well, albeit LS. It should have a mounting tab that helps position it where you want.
Old Mar 8, 2026 | 10:07 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
I have the Lokar one as well. Just wish that the handle was a bit longer.
Old Mar 9, 2026 | 07:19 AM
decurl's Avatar
Engine: 305 H.O.
Got a Lokar and got it installed. I like it a lot. Thanks Guys!
Old Mar 9, 2026 | 07:39 AM
hessm70's Avatar
Engine: 355 TPI w/AFR 195s Dyno Don Headers
Axle/Gears: Borg Warner 9 Bolt, 3.27 gears
I didn't want the dipstick attached at a header bolt so I found a ZZ4 oil dipstick. The tube itself attaches to the block 12551154 and the stick itself is 1255144 (bought from Summit). Now I have Dyno Don headers so no guarantee it works with yours.
boldguy
Jan 19, 2009 06:39 AM
BigWhiteGTP
Mar 25, 2006 12:24 PM
Slowmaro95
May 12, 2004 09:28 PM
jim86
Jul 1, 2002 08:11 PM
92TPIZ28
Aftermarket Product Review
Apr 28, 2002 04:01 PM
