Clean up Aftermarket Vortec Heads
Old Mar 13, 2026 | 05:15 PM
87SLEEPER's Avatar
Car: 1992 RS B4C
Axle/Gears: 3.23 10 bolt limited slip
Curious if you all think these heads can be cleaned up at home in garage? Or is machine shop ONLY option? Corroded from sitting. Never installed.
Thanks!
Old Mar 13, 2026 | 06:06 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: Clean up Aftermarket Vortec Heads
I'd want to have the flat surfaces milled, but there is work you could otherwise do yourself on those.
Old Mar 13, 2026 | 08:42 PM
Electrolytic cleaning, which is something you can easily do yourself, would loosen up most of that rust. It's not all that bad from what I can see. Then, cutting all the surfaces by acoupla .001"s to true them up, and you should be good to go.
Old Mar 13, 2026 | 09:13 PM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
If the valve springs have pitting on them then straight into the garbage they would go in my opinion.
Old Mar 13, 2026 | 10:01 PM
Pitting or no. Just... into the trash. Like any other valve springs on any other heads from any other unknown source in any other condition. Even if they "looked" brand new.
All the other valve hardware, the same. Quite possibly the valves themselves, particularly if they're stock. INTO THE TRASH. If you're building anything other than a construction site truck mule, INTO THE TRASH.
Old Mar 14, 2026 | 12:14 AM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
I would prefer a machine shop trip
Old Mar 14, 2026 | 09:00 AM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
If it's a budget project....which I'm guessing that it is, I'd 3M roloc pad the sh|t out of those, install them and go burn some rubber.
Old Mar 14, 2026 | 10:08 AM
87SLEEPER's Avatar
Car: 1992 RS B4C
That's the thing, I am trying to keep as a budget project. Car has good bones but needs attention all over to be road worthy and presentable . Goal is for weekend driver that is fun on the street. Not looking to drag or bragging rights . Just looking to wake motor up some along the way and keeping eyes open for good deals as I go. These heads for $200 seem like a good buy If they can be cleaned up on a bench with some new springs. If they need machine work for another 2-300 then it's not so much a good buy IMO, considering they are no name aftermarket units and I could just go buy them on eBay for 6-700 new, or even wait for another marketplace buy that may have like new version going for $500. I'm in no rush. Plus there is a sense of enjoyment I find by cleaning car up, yet keeping upgrades in line with what I consider the old school way, which is involves a certain level of elbow grease that an unlimited budget build may not need considered. This car is not meant to compete with those cars.
Old Mar 14, 2026 | 10:35 AM
Engine: LT1, L400
Got it. Yeah, I'd have zero issues with polishing those surfaces, changing valve springs and running 'em....after making sure that they're not cracked.
Old Mar 14, 2026 | 12:59 PM
Airwolfe's Avatar
What's the back story on this set of Vortec heads? They aren't a set you pulled off a truck at the salvage yard and stuck on a shelf in the shed outback to be forgotten.
I must not have scrolled all the way down to the bottom. I missed the last two replies.
CamG813
Sep 19, 2022 02:23 PM
Tuned Performance
Feb 18, 2022 06:46 PM
DeboDaddy
Jul 5, 2017 01:44 PM
Steve Mack
24
Sep 29, 2007 03:46 PM
EvilCartman
Aftermarket Product Review
29
Feb 15, 2004 07:49 AM
