1988 IROC 5.7 New Cam
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 1988 IROC 5.7 New Cam
Looks like a relatively stock cam with a little more duration. You may not feel much improvement of the engine so OEM injectors should work just fine.
Car: Trans Am GTA 1991
Engine: L98 with Super Ram and Fitech
Axle/Gears: 3.23:1
I run the 8800 with 1.6 rockers. It feels exactly like stock. You do not need to worry about injectors.
Wish I had invested in a two piece timing cover as I'd like to try the 8801 but there's now way in h3ll I'll spend another Sunday under the car getting the timing cover to seal up properly to the oil pan. It's too much work imho changing cams
Car: 87 IROC L98
HA! I use a Milodon gear drive timing system. Taking off a stock cover to change a cam is easy.
Axle/Gears: 3.23:1
Btw, doesn't the knock sensor complain on your gear drive?
