zz430??????
Old Jan 26, 2002 | 12:27 AM
SCOTTCAMARO1's Avatar
zz430??????
ok im in the process of building a semi copy of the ZZ430,for my car and i want to use tbi...instead of the fast burn with the 210 cc intake runners ill be useing the regular votec heads with 170cc runners,ill be useing the hot cam,and prolly a sinlge plain intake,if not ill be useing a rpm air gap,i've got the 670 holley unit,im shooting for around 9.8 compression,according to dyno 2000 it pushes 390hp@5000 and 459ft lbs @3500.with traction and a alot of praying im hopeing to dip into the 12's!!....anyinfo as far as the PROM goes...like who can burn a prom for this or if you all think im crazy for trying this combo...but with some bigger injectors and the custom prom i dont see much trouble with this combo
Old Jan 26, 2002 | 07:32 AM
ede's Avatar
ede
learn to burn your own proms, visit the prom board and read and learn. personally i wouldn't do it, but then again i've got a hot rod wit ha v6 in it and how many people would do that.
Old Jan 26, 2002 | 07:52 AM
Mike Crews's Avatar
SCOTT....
I just finished my motor a few months ago, and was faced with the same prom dilema that you are. I do intend to learn to burn my own proms, but I didn't really want to get into that right now. So, I had Dean at Street and Performance (in NLR, Arkansas) do a prom for me. I actually traded him my old Edelbrock 3860 intake for the chip, but his chips normally sell for $225 (a lot chepaer than an Ed Wright chip). I have been through several cars and proms in my time (Camaros, Vettes, ZR1s/ Hypertech, TPIS, MTI), and I can say that Dean has done the best chip that I have ever had (and TPIS was the worst). He works with you over a period of months, and sends you several chips (I've been through 7 chips) to make sure that you get the perfect chip. He doesn't just blindly sell you a chip and then forget you. However, you'll need access to a Tech 1 or laptop to get good data so he can dial in your chips. Plus, Dean has a good bit of experience with the vortec heads. You can call (or e-mail) him anytime about your car, and he loves to talk with you about getting it right.
Just my 2 cents (I should get a commission from Dean, I think I'm his best salesman)......
Later, Mike.........
bigarmzz
Nov 15, 2013 04:58 PM
crazyd
26
Dec 10, 2008 01:59 PM
AustinT
Oct 29, 2005 02:06 PM
Soulrev
Aug 24, 2002 01:32 PM
