Two EASY questions - TPI
Old Jan 26, 2002 | 03:27 PM
Convert's Avatar
Car: 1987 Iroc Z
Engine: 5.7L TPI
Ok, i hope that this is the right board to post this.
1) Where is the fuel pump fuse located. Which Fuseblock??
2) What (if any) are the torque specs for reinstalling the throttle body to the plenum (4 bolts), and the plenum to the intake runners (8 bolts)? I don't want to strip any alluminum here, but i don't want any vaccum leakes either.
Thanks Guys
Old Jan 26, 2002 | 05:06 PM
rondubbs's Avatar
fuel pump fuse is located near the battery,, im assuming you are going to take this out because you want to alleviate the fuel pressure.. no need to,, let the car sit overnite, take the gas tank cap off, and release and other pressure by pushing down the schraeder valve.......
all your torque spec needs are found here:
http://www.racer-x.f2s.com/proc/torkseq.htm
:lala:
Old Jan 26, 2002 | 05:12 PM
Convert's Avatar
Car: 1987 Iroc Z
Engine: 5.7L TPI
Hey man, thanks for the link. But should i pull the fuse block if i am changing the fuel filter?? I am also putting on an AFPR.
Old Jan 26, 2002 | 07:40 PM
rondubbs's Avatar
no, dont pull the fuse....... let it sit overnite and then whatever pressure is left will be out when you take the gas cap off and push on the schraeder valve
:lala:
Old Jan 26, 2002 | 07:52 PM
Convert's Avatar
Car: 1987 Iroc Z
Engine: 5.7L TPI
Ok, ill do that Thanks for your help, it's greatly appreciated.
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Sanjay
Aug 12, 2015 03:41 PM
