wanna run 12's
wanna run 12's
hey guys, I'm saving up some money for some heads(maybe eldelbrock alluminum) and cam,runners,headers throttle body. etc. what would it take to get my car running about12.5 in the 1/4? would the things I listed about do that? also I'm planning on rebuilding the motor also.
Car: 99 Formula
Axle/Gears: 342
You said you ran 14.2 now right? That mean you have to drop 2 seconds. What gears do you have in their now. If 2:73s, go w/ 3:73s (since you plan to mod the TPI) and a higher stall TC. That should drop you 1 second right there. Now with heads and a cam, and headers that should drop you close to another second right there. At worst you'll be at 13 flat I would think. Of course this is just my opinion.
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Don't spend your money on a TB, its not needed. Theres better things u can use that $$ on.
Why do you think chevy puts them on the ram jet 502ci
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
