She No Go..
Old Jan 27, 2002 | 11:52 AM
FatOne's Avatar
She No Go..
Have 350 TPI, car starts fine. When shift into a gear the car will die. I can shift into neu. without problems. When I shift into either rev. or drive its seems like there is no power to keep the eng. running. Yes the car needs a tune up. I was just wandering what you guys think.
Old Jan 27, 2002 | 12:57 PM
sleeper's Avatar
why don't you ask us again after you do the tune up...
Old Jan 27, 2002 | 02:39 PM
Vader's Avatar
As part of your "tune up", you might want to remember to clean the throttle body and IAC air passages. To complete the procedure, you should always check the TPS voltage and adjust as necessary.
For steps to a complete tune up, search the archives.
Old Jan 27, 2002 | 08:57 PM
mckenzie's Avatar
i would agree with vader, clean iac and iac passage, and also clean the throttle body. might want to use carb/choke cleaner. best of luck, tom
Old Jan 28, 2002 | 02:27 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Off the wall guess here, but could be the TCC is locked up...jst something to check.
Can't be too far out of tune to idle in gear, since it starts right up???
BlackMamba
17
Jul 10, 2011 02:05 AM
jak
Feb 14, 2011 08:45 PM
whyt86roc
Oct 8, 2010 07:44 PM
snowflake
Sep 25, 2010 11:52 PM
drwiggle
Sep 20, 2003 08:33 AM
