aftermarket intake
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
aftermarket intake
which aftermarket intakes would not result in hood clearance probs on an 83 bird 305 4 barrel and stock airbox?
Car: 99 Formula
Axle/Gears: 342
I think they would all be fine except high rise one's like the Performer Air Gap, the Edelbrock Performer and RPM will fit.
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
actually the airgap and perf rpm are the same height 4.65"
the performer is the only one that will fit a stock hood without a drop base aircleaner.
Check out the Weiand 8004 or the one in the 8000series that's right for your car. Of the lower rise manifolds it outperformed HOLLEY AND Edelbrock in a Hod rod manifold comparsion some yera back.I'm not positive if it will clear but some one like Summit or Jegs may have a application chart.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
