Setting ignition timing
Old Jan 28, 2002 | 02:08 PM
Marc 85Z28's Avatar
On an 85 LG4, is it necessary to disconnect the computer's timing
advance wire to set base timing? I can't find any single brown wire with a connector anywhere near the distributor. Where should I be looking? Also, if setting the timing with it still connected is supposedly cancelled out by the computer, why does my motor run better with 10* advance set with the computer still hooked up as compared to 0*?
Old Jan 28, 2002 | 05:13 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
With a computer contolled carb.( think thats what yours has) you can just pull the four pin connector out of the HEI dist. W/ teh fuel injected cars, the timing connector is in the very back of the passenger side of the engine compartment in a wire loom. The loom runs over everything so its pretty visible.
Old Jan 28, 2002 | 05:15 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Also, follow the instructions on the lables located on the front underside of the hood
Old Jan 29, 2002 | 09:55 AM
Marc 85Z28's Avatar
Thanks.
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
justin57
Aug 20, 2015 07:05 PM
