The smell of fuel......possibly the fuel filler neck??
Old Jan 28, 2002 | 02:17 PM
BowtieFever's Avatar
My 92 Camaro tends to smell like gasoline when I fill it up. I also suspect that it may leak gasoline. I know that it is NOT the gas cap. Could this be my fuel filler neck. Were most cars fuel filler necks replaced, by the dealer, from the recall? Also, how much does a dealer charge for the fuel filler neck?
Old Jan 28, 2002 | 03:37 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
It's very likely that your car has a problem with the filler neck. Almost 1/3 of 91-92 camaros were recalled for it. Interestingly enough, my 91 has the same problem, yet there is no recall on it, and they refuse to fix it. GM can kiss my @$$ on that one. On my car when I look underneath it, up to the filler neck, I can see where gas has run down the underside of the gas tank.
Old Jan 28, 2002 | 05:07 PM
ChevalierSS's Avatar
F-bodies are notorious for leaking in the neck. If you have to take the VET test it can cause your car to fail the sniffer. The fumes can get sucked in to snokle cones.
Eric
1992 Trans Am
May 10, 2023 07:19 PM
chazman
Aug 28, 2018 03:25 PM
dyeager535
Aug 28, 2015 08:10 AM
chazman
Aug 22, 2015 02:01 PM
