Estimated power or times
Old Jan 28, 2002 | 10:28 PM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
Guy at work is building a mild 350 as he calls it.
He said he'll be using the following, if someone could help me find about how much horsepower or what times he'd run that'd be great.
350 standard bore.
10:1 compression
Holley System Max alum. heads (2.02 , 1.94 valves I think)
Holley System Max cam, lifters and intake ( cam around .480 lift and 250 int. 270 ext. advertised I believe)
with probably a 700-800 cfm carb.
He's hoping to pull high 12s at about 110 in a el camino. Do you think it'd be possible?
Sorry for the rough estimates, it's all I have at the moment.
Old Jan 28, 2002 | 10:55 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I'd say anwhere between 12s-14s. Like you said you don't know a lot about it. Exhaust will play a major role, which I'm assuming will be headers, but you didn't state. What about gears, what tranny ( TC if applies). These could all greatly affect the outcome.
With the right exhaust, I'd say about 400 HP, 380 ft/tq
Old Jan 29, 2002 | 12:00 AM
Ions91Z28's Avatar
Sorry, missed the above. That just seems greater than I had planned. Though I guess it's quite possible. I believe he's getting the heads, cam, and intake for a little over 1000.
I believe he's running headers with full exhaust, turbo 350 with a 4.11 gear. Not sure about TC.
Old Jan 29, 2002 | 12:23 AM
87transam5.7tpi's Avatar
hooking up in an el camino will be kinda tuff. if you had on slicks I would guess about 12.6 or so. just my guess
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bellez77
Sep 5, 2015 08:39 PM
86White_T/A305
Aug 17, 2015 12:16 AM
