Timing chain to oil pan seal question
Old Jan 29, 2002 | 02:17 PM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
I was taking apart an 86 TA the other day as part of a cam swap and had a bit of trouble getting the timing chain cover off. Turns out the seal at the bottom of the cover was part of the oil pan gasket. I always thought that was a separate gasket (in fact, the replacement gaskets I got have that as a separate piece).
It's good rubber and appears to be in good shape. Any reason that I can't just coat it with motor oil and re-use it? And, any opinions as to whether that gasket is stock or not?
Old Jan 29, 2002 | 02:30 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
felpro (and rol) makes onepiece pan gaskets now
I don't know that gm used them from the factory. I get the impression someone had the pan off b4.
Old Jan 29, 2002 | 02:33 PM
99Hawk120's Avatar
Hmmm... the car has approximately 10x,000 miles on it and he put about 70,000 of those on it.
When did GM start using RTV for the front and rear intake manifold seals instead of the china wall gaskets?
I'll tell you one thing though, no one has ever had the valve covers off. Those suckers were GLUED on...
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
matthew911
Aug 12, 2015 09:38 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
gwade12
Aug 8, 2015 08:17 AM
