water pump question
Old Jan 31, 2002 | 12:01 AM
len's Avatar
len
water pump question
ok i have a 86 L69. i was wondering what water pump i should have reverse or standard flow.i read some where it should be reverse but i think that was for a tpi. i need to know cuz i sparked her up today at -22 and within 15 mins the fan kicked in, and in the summer it's even worse. the rad was flushed preasure cheaked, and a new cap and stat. the only thing i can thing i can think of is the water pump rotation, it has been changed before i owned it, maybe they put the wrong one on. i know 3rd gen's run warm but this is insane, any tips on keeping it cool would be tremendesly appreciated thanks!
Old Jan 31, 2002 | 12:55 AM
Vader's Avatar
len,
If your engine has the standard 37° 'V' belts (as an '86 probably should) it should use a standard rotation water pump. It is possible that a gasket is positioned improperly, blocking a port, or that the impeller is slipping on the pump shaft.
Old Jan 31, 2002 | 05:56 AM
Jza's Avatar
Jza
You're coming to that conclusion just by the fan coming on? Did you actually measure the coolant temperature?
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
