Dummy 02 sensor
Old Jan 31, 2002 | 03:57 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Dummy 02 sensor
I've heard of 4th gen guys using O2 dummy sensors. How do these work. Anyone know?
Tks
Old Jan 31, 2002 | 04:43 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
The dummies are for after the cats on OBD2 cars (96-up in f-bodies)
OBD2 uses 2 sets of O2s, one in front of the cats for normal purposes, and one behind the cats to make sure the cats are working properly. If you gut the cats, the second O2s will see it and set a code. Dummies send the 'right' signal to the ecm, thus no code.
Old Feb 1, 2002 | 07:16 PM
Rob P's Avatar
Engine: ZZ4TPI
OKay, next question. Seems the ECM likes to see a 600mv before it accepts the o2 sensor as working/not working and allowing the car to go into closed loop. Can you reprogram the chip to make that value like 500mv vs 600mv?
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
