connecting rods???
Old Jan 31, 2002 | 07:50 PM
Harley83's Avatar
connecting rods???
im planning on building a 420 hp motor and it has all the goodies 234 intake duration cam. 2.02 heads TH-350 heads and a 750 cfm carb.. my question to yall is this will be pushing about 420 hp and i was wondering if stock rods and crank could hold up.. its a four bolt block out of a 86 pickup. and does anyone know of places to get cheap rods such as i beam or refurbished shot peened rods if this wont work out...
thank ya
harley
Old Jan 31, 2002 | 08:26 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
replace the rod bolts and have the bigend resized
You can get an aftermarket rod for about the same price. around 200bucks. check ebay for 5140s
Old Jan 31, 2002 | 11:32 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
just curious if your going with a 350 isn't a 750cfm carb a little overkill?
doesn't get a large carb like that kill low end power due to lack of velocity and since your motor is not going to get any where near the max flow rate of that carb unless you rev the **** out of it I would think it could kill your high end a little alos by not keeping the air moving as fast as it could
Old Jan 31, 2002 | 11:49 PM
Harley83's Avatar
not really the 750 cfm aint overkill cuz im running a dual plane manifold with a 234 duration cam so its just about right could be a little too much but oh well its what you sacrafice for performance
Old Jan 31, 2002 | 11:51 PM
87transam5.7tpi's Avatar
scat sells some 4340 rods for a 350 for $250 and I'd then get a 5140 crank from CAT they run about $500. that would give a strong bottom end.
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Sep 16, 2015 12:37 AM
TOMcat GTA
Sep 15, 2015 09:31 AM
Street Lethal
Sep 7, 2015 01:09 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
