Not Thirdgen Related But Need Help
Old Feb 1, 2002 | 08:16 AM
Momar's Avatar
My mom has a 97 blazer and the check engine light came on. Is there any way for me to check the codes it its computer like you could with the older cars. Can I just use the paperclip like you do to flash the engine light on our cars? If so what pins and where would her connector be located?
Ben
Old Feb 1, 2002 | 08:24 AM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
The computer is OBDII (93ish and newer cars) and as far as I know (I could be wrong) the paper clip trick doesn't work. I used to work for Murray's Dicount Auto and what we did was loan out scan tools for OBDII. It's $200 for the unit and another 100 for OBDII cartridge but you get a full refund when you return it. It's an amazing tool, especially on OBDII cars and will tell you absolutely anything about your car including trouble codes, all you need to know is the make model and engine code. I know we have Murray's in Chicago but I'm not sure about elsewhere in IL. Call around some other parts stores and see if they do the same thing.
Old Feb 1, 2002 | 09:47 AM
Momar's Avatar
Thanks for your help. I guess if you cant do it without the scan tool that will probably be my only option. I just thought it would be nice to be able to just run out and check it real quick. I hope someplace around here does that but I dont think that they do. What brand of scan tool did you use?
Ben
Old Feb 1, 2002 | 12:41 PM
Car: '87 Camaro LT
Engine: 355 L98
The name of the company has slipped me at the moment but in looking for it I found this: http://www.ghg.net/dharrison/obdscan.html
The_Phoenix
Feb 4, 2016 07:10 AM
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
86IROC112
Aug 21, 2015 07:20 PM
Jk_Under
Aug 17, 2015 03:08 PM
redmaroz
Aug 16, 2015 11:40 PM
