Not thirdgen but please help
Old Feb 1, 2002 | 10:02 PM
3504mula's Avatar
Car: 90 Formula
My Calais' (quad 4) air/oil seperator went bad and caused a lot of oil to pour into my intake, throttle body, and air filter. It now runs like it is running off of 2 cylinders. I replaced the air/oil seperator, air filter, spark plugs, and oxygen sensor. It still barely runs. It is throwing no codes, though. I didn't want to take it anywhere, but if no one can help me then I guess I will because I don't want to spend any more money if I am just going to need a rebuild. Any ideas on what is going wrong???
Any help is greatly appreciated.
Old Feb 1, 2002 | 10:22 PM
Vader's Avatar
Formu 350,
I feel your pain. I have a four-holer that did the same thing. How is the compression? If enough oil was admitted to the chambers at once you may have slammed a piston hydraulically. It would take a lot of oil, and I don't know if that much could get past the separator at once, but it's a possibility.
Another thing to check is the MAP sensor. The diaphragms really don't like a lot of oil, and you may have suffered some damage if the system was oil soaked long enough. It should probably set a DTC if it were that far out of range, however.
As long as the cylinders were clean when you installed the new plugs, it should run acceptably. If there was residual oil in the chambers and intake runners, you might have trashed the clean plugs almost immediately. Try removing them for inspection and cleaning if necessary.
You can also remove a spark plug wire one at a time from the running engine to help locate a weak a dead cylinder. Insulated spark plug wire pliers are almost a must for that method. There should really have been no other permanent damage caused by the oil in the intake or chambers, unless of course you slugged the oil in all at once as described earlier.
Old Feb 3, 2002 | 12:43 PM
3504mula's Avatar
Car: 90 Formula
Thanks for the help. I tested compression and all were fine. I'll try a map sensor today and let you know.
Old Feb 3, 2002 | 03:08 PM
3504mula's Avatar
Car: 90 Formula
Well I tried a new MAP sensor, with no luck.I guess it is timing related. Anyone ever changed the timing gear on a DOHC engine? If so, how hard is it and are there any special tools needed? Thanks for any help.
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
fastrs1891
South Central Region
Oct 20, 2015 09:24 AM
Exxon Limited
Aug 9, 2015 08:13 PM
