Problems with the RPM Air-Gap...
Old Feb 4, 2002 | 12:24 AM
Fbird88's Avatar
Car: 1988 Firebird
Engine: GM Performance Parts 350 HO
Axle/Gears: :(
I have the Edelbrock Air-Gap manifold, and I'm having problems installing the oil pressure sensor. For some stupid reason, Edelbrock decided to cast 2 distributor hold-down platforms on this intake instead of the 1 on all their other manifolds. This useless extra platform doesn't allow for enough room to install the sensor. What did you guys who have this intake do to solve this problem? I'd like to avoid grinding it if at all possible. Any ideas would be greatly appreciated. Thanks.
Old Feb 4, 2002 | 06:16 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
go to your local welding shop and get a brass fitting
that will allow you to raise the op sensor. Carry it with you and they will help you find the right one.
355tpipickup
Aug 27, 2015 08:13 AM
Regal105
Aug 23, 2015 03:45 PM
forstral
Aug 19, 2015 03:20 PM
hokis
Aug 9, 2015 03:57 PM
