What CR w/58cc heads?
Old Feb 6, 2002 | 12:06 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
If I go from 64cc to 58cc heads what would that make the compression ratio? Assume starting CR of 9 or 9.3:1.
Old Feb 6, 2002 | 01:10 PM
xxwarrior36xx's Avatar
stock I think is 9 so you would get 9.5 compression I think. I saw a hotRod that did that and that was the result.
Old Feb 6, 2002 | 08:49 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
You cannot make that assumption, unless we know more.
1) What size engine in cubic inches?
2) Any overbore?
3) What are the reliefs in the piston rated at?
4) How far down in the hole are the pistons at TDC?
5) What size thickness is the head gasket that you will use?
Once we know these figures, we can calculate the change in compression ratio.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
